16-04-2024 01:37 PM
I am dismayed to find that TPTV isn't available on EE/BT TV, although it is on Virgin, SkyFreeview and Freesat. Are there any plans to make this popular channel available?
16-04-2024 03:19 PM
I'm not sure about talking pictures as I am not sure if they are on other competitors IP services, but the Great! Channels definitely are, so would be good to see them at some point.
Since BT started IP channels there hasn't been much added to the list unlike competitors where there are regularly additions.
You will probably need to switch your TV to Freeview as and when required for Apple TV and mini boxes, or if its the BT TV Pro, you would need to reset it to factory settings with an arieal plugged in to change it to arieal mode.
