28-08-2022 07:14 AM
28-08-2022 07:42 AM
What device do you have?
How long have you owned the device?
28-08-2022 07:53 AM
28-08-2022 08:15 AM
What is your batter usage stats under the battery settings?
Tbh I have the same phone and the battery isn't great compared to last year's device. If you have all the top settings (screen etc) active then expect 12-24 hours if you're a regular user.
28-08-2022 08:25 AM
28-08-2022 08:35 AM
What's your usage as per the batter app?
28-08-2022 08:37 AM
28-08-2022 10:54 AM
Could you have a look, @farinakamall8?
It should break down which apps are using the most battery power.
