Roaming won’t work in US after purchasing add on and activating it in store. ?
DougBayliss
Hi there,
My roaming add on bundle isn’t working in the US after purchasing and activating  in store.
Any help or advice would be appreciated as I am stuck without incoming or outgoing calls here for four weeks.
Many thanks
Legend
Legend
If you are on pay-monthly and now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 0798586 using a web-calling app such as Skype over WiFi.
Thanks for the reply.
It was supposed to have been done in store by one of the ee shop assistants.
I do get the R symbol appear on the top header where it shows you the signal strength and battery percentage, but I just can’t make or receive callas or email .
I was totally stuck in LAX airport and not able to call a Taxi or anything to get me to my destination, was so peed off with this.
it’s the second time I’ve been  let down by ee while abroad. The first time I had a Huawei phone which when I stated I was going abroad and needed Roaming activated, nobody told me that the US had deactivated most of its Huawei masts.
Not amised.
You've certainly been spun a yarn there! You may be confused with the US' 2G/3G switchoff which creates a requirement for a VoLTE-compatible devices in many areas.
There is no requirement for a "Huawei mast" to get coverage on a Huawei phone. In the same vein as EE are currently deploying a combination of Nokia & Ericsson radio equipment, which is fully compatible with both Apple & Samsung phones.
