18-12-2023 10:38 PM
Hi there! Really hoping someone can help.
I'm currently abroad -- in Argentina -- and my iPhone 13 Pro isn't picking up any signal, at all.
My phone is picking up the networks (as in, I can see them when trying "manual" selection) but each has no service. My partner (who is on O2) did the same and has full 4G signal on all 3 different networks.
Tried restarting my device, toggling flight mode on/off, and reseting my network settings. Roaming is enabled and working fine before. I was in France last week and my signal was absolutely perfect.
Can anyone help?! I'm desperately needing to receive texts with specific codes, so I'm able to log into accounts of mine. Going away on a cruise -- which'll have WiFi -- and need to be logged in before departing tomorrow.
Thanks so much!
18-12-2023 10:23 PM
Thanks so much!
19-12-2023 12:18 AM
How is roaming enabled? It needs to be on your a/c, not just on your device.
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
Often just rebooting the phone is the simple remedy. Also try selecting a network manually rather than auto. Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
19-12-2023 09:14 AM
Your account may have EU-only roaming enabled, which would explain your symptoms.
Your only recourse is to contact EE CS from another means, and ensure full global roaming is enabled on your account.
