19-12-2023 05:51 PM
Hi I am in India and I set up using data pass but I not getting connected, no network.
i can only use WiFi in hotel
please help as I stranded, I can’t even call EE
19-12-2023 05:57 PM
Hi @nailamughal
If you haven't activated roaming on your account then pass will not work. You'll need to download Skype and use the number in my signature to speak to EE CS to activate roaming.
19-12-2023 06:08 PM
19-12-2023 06:12 PM
If you now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 0798586 using a web-calling app such as Skype over WiFi.
