14-01-2024 11:54 AM
My signal is completely rubbish now at home also. My daughter gets no signal either. This has happened in the last month. I can hear the caller but they cannot hear me. It is not my phone. It works fine when I head on up into town. EE say there is nothing wrong in my area but something has changed with the signal strength it used to be good. I will have to leave them
14-01-2024 02:14 PM
Welcome to the community.
I'm sorry to hear that you're having some problems with your service. If you pop your postcode into our coverage checker and hit check status, it will let you know if we're aware of any maintenance works in your area. If we're not aware of any, it will give you an option to report a problem so that our network team can look into it.
14-01-2024 09:55 PM
You allude to two different problems. If you're not getting any coverage (either 4G or legacy 2G/3G) since recent times, that could be due to optimisation or a network outage. In either case, using the coverage checker and the "report a problem" is a good first stage.
The same problem reporting facility includes an option to report in-call voice issues.
