11-08-2021 05:10 PM
I have a number of listed data uses to eeuk6050. As my data roaming is turned off I don't understand these entries and am not aware of trying to access or use data other than by an internet connection. Can anyone explain this please?
11-08-2021 05:58 PM
You get some free data as well with PAYG packs and if any app is running it may use a bit of that data & for some reason it is reported in mins in the usage report.
There are always some apps running in the background, perhaps checking for their updates & updating themselves. Try restricting background data & update only over WiFi.
11-08-2021 06:33 PM
I have turned data off on my sim. is that what you mean
11-08-2021 06:40 PM
I was talking about your device but you may consider your SIM to be the same thing.
11-08-2021 06:58 PM
I already had data turned off in roaming and this was the only other place I could locate a setting. As you can probably tell I'm not terribly phone savvy. It is an android device by the way.
11-08-2021 07:13 PM
It's nowt to do with roaming if you're in UK. Look at its Data Saver.
11-08-2021 07:27 PM
Thanks for your patience. Data saver is turned off
13-08-2021 12:38 PM
Further to Data saver, having turned it on, I then turned it back off again as I don't really understand which is the better option. Can someone spell out the pros and cons. Sorry to be so dim and thanks
13-08-2021 02:43 PM
Hi @grouser
What phone are you using?
Do you want to turn off all data on your phone?
Thanks 🙂
15-08-2021 09:25 AM
Hello Leanne,
A Motorola G8 power.
Yes I think so
