data usage
mally1403
I have a number of listed data uses to eeuk6050. As my data roaming is turned off I don't understand
James_B
Hi @mally1403,
Turning off data roaming will only stop your phone using data abroad. If you'd like to turn off mobile data, swipe down on your home screen to access your quick settings and tap the mobile data icon.
Hope his helps.
6 REPLIES 6
James_B
Hi @mally1403,
Are you in the UK or abroad?
What type of phone are you using?
In the UK and Samsung galaxy s7
Are you being charged for it? You get some free data as well with PAYG packs and if any app is running it may use a bit of that data & for some reason it is reported in mins in the usage report. It should have a cost of £0.00 against it.
ISPs: 1999: Freeserve 48K Dial-Up => 2005: Wanadoo 1 Meg BB => 2007: Orange 2 Meg BB => 2008: Orange 8 Meg LLU => 2010: Orange 16 Meg LLU => 2011: Orange 20 Meg WBC => 2014: EE 20 Meg WBC => 2020: EE 40 Meg FTTC => 2022: EE 80 Meg FTTC (no landline number)
Not being charges just using up my dataSent from my Galaxy
James_B
Hi @mally1403,
Hope his helps.
thanks
