13-12-2022 12:55 PM
Hi
I got a text from EE saying I have used all the data I gifted but I never gifted any data and I cant see the 'family usage ' tab to stop gifting the data , can anyone help ?
13-12-2022 01:09 PM - edited 13-12-2022 01:10 PM
It's only talking about data that you may potentially gift from the 1st 100GB of all your data to other nos. on your a/c if you choose to. It's just a warning just in case you wanted to. You may safely ignore it & carry on using data for your own purposes including hotspotting.
As you use data for your own use you are eating into this gifting allowance even when you are not actually gifting it.
It didn't say "You've gifted all the data you can gift" just that "You've used all the data you may gift".
13-12-2022 03:52 PM
Ah perfect thanks Ray
13-12-2022 04:35 PM
