08-02-2022 08:42 PM
I'm having same issue. There seems to be a problem with the system. 4 times I've purchased the 15 pack and it says successful but then check data and nothing shows up. Its ridiculous!
08-02-2022 08:59 PM
@Naomiwatson : What does texting AL to 150 from it fully report verbatim (it is free)?
08-02-2022 09:21 PM
NOTHING! Now my payment has gone through and pack is started I've got no phone, can't text and no data, says proxy settings check but why would that affect calls?
08-02-2022 09:53 PM
@Naomiwatson : What do you mean by "Nothing!". There must be some msg or response.
09-02-2022 08:10 AM
Hi @Naomiwatson
Can you send the text to 150?
What phone are you using?
Thanks 🙂
