05-02-2022 06:26 PM
I have an iPhone 8 Plus. Almost all of my apps don’t work properly and emails won’t load when I switch from wifi to 4g. The network coverage in my area is apparently fine, I have tried all the usual hacks like restarting the phone, switching wifi / mobile data / Airplane mode on and off, resetting network settings etc. When I try to use mobile data in various apps I get a message saying that my phone is not connected. Messages will come through on WhatsApp hours late / not send for hours. I have been stuck out late at night and not been able to use a taxi app to get home safely. The phone seems to work fine for (non-wifi) calls though and interestingly mobile data seems to work when overseas on roaming. Therefore sounds like a local network issue / connection issue. I’m basically paying a fortune for a business plan for a phone that only works when I’m at home / the office on the wifi!
06-02-2022 01:38 PM
Hi @Kath_E
Are you on PAYG or pay-monthly? And have you checked (by sending AL or BALANCE to 150) that you have available allowance?
Have you used mobile data on this device previously, or has it never worked?
Do other EE users in these same locations have similar problems? If there's a network issue, it would affect all users.
06-02-2022 04:35 PM
06-02-2022 05:11 PM
Instinctively, I'm minded towards this being a device fault.
If you know any friends or family who use EE, I'd suggest comparing service with their phones next.
06-02-2022 05:37 PM
07-02-2022 07:14 PM
Just in case this might help other users, it appears that the problem may have been that I had a security app (McAfee) with an additional VPN installed. The mobile data seems to work fine once the app has been deleted. Not the ideal fix however as obviously the intention of having an additional VPN is increased security…
