08-05-2023 10:53 PM
Hi I reported my phone lost months ago then gave me a new phone and a SIM card with the same number does ee delete everything off my phone like wallet and photos and contacts and messages
08-05-2023 11:27 PM
Only whoever possesses it can delete or read any msgs.
08-05-2023 11:11 PM
No, if it's been lost EE has no access to it. They will just blacklist it so it can't be used on a mobile network but it could be used over WiFi.
08-05-2023 11:12 PM
If you had a PIN or other device-level security set, this could protect your personal data. If not, then anything stored on the phone would have been potentially free for a thief to use if they wanted to.
08-05-2023 11:14 PM
Oh so they can access my wallet and everything cause I didn’t have a pin at the time on it
08-05-2023 11:15 PM
That's right! You left it at risk.
08-05-2023 11:18 PM
Is there anyway it can be deleted?
08-05-2023 11:21 PM
Not by you, unless you can re-find it.
08-05-2023 11:22 PM
Alright thanks for your help but will it delete my old messages or again unless I find it cause some messages are important
08-05-2023 11:27 PM
08-05-2023 11:44 PM
Also with my new phone and SIM card if I call and message on my new phone will my old phone get the messages
