22-03-2022 06:24 AM
I did an upgrade and now can not use some sites
22-03-2022 08:34 AM
Morning @Jimbabs
Thanks for coming to here.
What message do you get when you try and access these sites?
Can you use your apps?
Thanks 🙂
22-03-2022 06:49 PM
@Jimbabs : It could be your Switching Content Lock OFF or ON . It is switched on on new & upgraded contracts & seems to affect social sites. If just switching it OFF doesn't help, try switching it to STRICT, reboot your device and then switching it to OFF. That is seeming to do the trick.
