EE WiFi
blue-agila
Valued Contributor
Valued Contributor
Why as an EE Mobile customer do we not get free access to EE WiFi when BT Mobile customers had access to BT WiFi
Northerner
Hi @blue-agila
You can
https://ee.co.uk/help/mobile/manage-use/using-phone-features/use-ee-wifi
Just watch out for WiFi  hotspots spoofing and always use a VPN on any public or carrier WiFi networks.
To contact EE Customer Services dial 150 From your EE mobile or 0800 956 6000 from any other phone. You can call Freephone +44 800 079 8586 on Skype
EE standard opening hours are 8am to 10.30pm every day.
Mustrum
I suspect the OP means the BT WiFi that is now being called EE WiFi via customers routers. The whole thing is a little confusing, and may well change in the future. It was also free to BT Broadband customers, but noy (yet) for EE broadband customers, or mobile ones.
https://ee-wifi.ee.co.uk/public/ee/index.htm
blue-agila
Valued Contributor
Valued Contributor
When you try to log it does give the option for EE Broadband customers but not mobile
Im talking the new EE public WiFi hotspots formally BT public WiFi
@blue-agila   It is not free for any EE customers, the log in options are just ways to identify you as a customer.
It is a bit confusing, and things may change, but nothing has yet been announced - maybe a future option - with luck.
