29-04-2024 07:53 PM
My phone has lost all connectivity while I’m in Europe. Lots of data allowance left
signal strong
can only connect via wifi
29-04-2024 07:56 PM - edited 29-04-2024 07:56 PM
@FraserSpeechley : Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before you left to go abroad?
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
