29-04-2024 08:18 PM
29-04-2024 08:26 PM - edited 29-04-2024 08:27 PM
You may use your usual UK allowances in the EU with up to 50 GB (contract) or 25 GB (PAYG) data per billing month if you have more. If on contract & your contract started after 07/07/2021 there'll be a £2.47 / day charge for using your UK allowances in EU or alternatively you may buy the Roam Abroad Pass for £25 / billing month.
As you are on contract, remember to text ROAMING to 150 before you leave UK to ensure the roaming ability is enabled on your account.
29-04-2024 08:21 PM
Do you have a question about using your phone in Greece?
29-04-2024 08:21 PM - edited 29-04-2024 08:22 PM
@Demijack81 : What about it? Are you there or are you going?
29-04-2024 08:24 PM
Yes, do I need to change anything before I go? I struggled out of the eu the last few times , had a contract for about 14 years with everything on it I think
