14-03-2023 09:17 AM
Does anyone know how to see how much data they’ve used a month. I’ve unlimited data so it seems as though I cannot see my useage but I’d still like to know it.
14-03-2023 09:28 AM
Not for unlimited plans. You will get warnings when you used 80% & all your giftable data.
14-03-2023 10:48 AM
Hi @chrisdymond22,
What type of device are you using? If it's a phone or tablet, you should be able to track your mobile data usage in your settings.
03-06-2023 11:08 AM
Mobile. If Apps are gobbling up my monthly data allowance within 24hours.
I need to get EE to list them for me so I can turn them off. My allowance currently dissapears without me using it consciously. Thanks.
PS Is there a youtube on this.
I also need a Data Usage Control icon on my front screen so I can check it at all times.
PPS also need a Battery Left icon on the front screen, without needing to go into Settings/Battery. Its a pain I dont need.
Thanks.
03-06-2023 11:48 AM - edited 03-06-2023 11:58 AM
@OurVaughn EE don’t set the device functions on what you can see on the device. That’s the manufacturer of that device and their OS. But have a look in your device settings to see if something can be enabled for that battery. You might also have something for data settings.
You data allowance is just that an allowance and EE don’t log what apps are using what data but your device does. There are so many apps EE would need to code every single app available so their systems can log your usage via your account and just impossible to do.
On your device if you have apps updating/running in the background these will use data even if you are not using the device as that’s what apps can do in the background. Your device will show what apps are running in the background.
