10-02-2022 05:20 PM
I have a Samsung S8+ and am having difficulty contacting the internet in an area of Birmingham B6 6HE. This has been happening for longer than I can remember. EE advice reset the phone each visit. It seems funny to me that people around me do not seem to have any issues at all. I need to ask what network they are using. My partner has a Samsung A10 also has the same issue. Any suggestions would be helpful. Thought of changing model of phone but if stay with Ee will this make a difference
10-02-2022 05:44 PM
Hi @ChrisP54
Welcome to the EE community
Do other EE users in this same location have problems? If there's a network issue there, it should affect all users equally.
Does your phone show signal there, can you make & receive calls ok? What happens when you try to use data there?
10-02-2022 05:52 PM
I have exactly the same issue in an area of Birmingham, and the information I get from EE is to reset the phone, this has been done and still no access during the football, yet other supporters do not seem to have the same issues, Although I do not know which network they are using.
11-02-2022 07:51 AM
Hi @ChrisP54
Can you access data in other areas?
Have you reported this on our EE Coverage & Network Status Checker? If you select 'Check Status' you can report this to the network team.
Leanne 🙂
11-02-2022 08:03 AM - last edited on 11-02-2022 09:11 AM by DanielPA
Yes I can access in all other areas, and yes I have reported to to EE. There response was to reset phone, and to contact them when having difficulty in the area, which is a little difficult when surrounded y 41,000 people at a football stadium
Thank you
xxxxx xxxxxxxx
[Mod edit: Please do not post personal information on the public board. Thanks!]
11-02-2022 08:11 AM
Do you have the same problems when there isn't a football game being played?
Or is this only happening then the football stadium is full?
11-02-2022 08:26 AM
