Data Usage Roaming Personal Hotspot Other Devices
Andyj0934
Currently abroad in Dubai, using my Apple iPhone. My one gigabyte of data is lasting approximately 30 minutes if I’m lucky. I am not using the phone for any purpose other than receiving texts, WhatsApp messages and phone calls. I can see the Data Usage via the usage information on the phone which is minimal. The problem is my personal hotspot is saying other devices is using all my data. However, there is nothing connected to my hotspot and it’s switched off. Please can anybody shed  any light on a remedy for this problem thank you in advance?
8 REPLIES 8
Legend
Legend
Try changing the password for your hotspot. Does the issue persist?
Can you see data usage increasing in real-time even when the function is disabled? Or are you just checking it periodically, and using the function at other times?
When I switch roaming on it’s jumping up in tens of Mbs per minute or so but showing only as personal hotspot other devices. The hotspot is definitely not and there are no devices connected.
When roaming is off there is no increase
cheers
Legend
Legend
Yes still the same issue
becoming very interesting 🧐
 And the hotspot is definitely off with nothing connected 🤔
Christopher_G
Hi @Andyj0934
Has the amount of data used increased since you turned the personal hotspot off?
 This the thing the hotspot is off and there is no connected devices so at a loss as to what is causing the problem.
@Andyj0934   Have you tried just restarting the device?
Legend
Legend
If you text BALANCE to 150, does the information correlate with the phone's counting?
