Mesh wifi hub not connecting to EE data sim in Huawei mobile router
The_cheatman
I have a Huawei CPE pro router and a tenda nova mesh wifi system. The set up works perfectly with my O2 sim card but when I put my EE sim into the router the mesh system is not able to connect. I have tried restarting and any other simple fixes but the problem persists, as soon as i revert back to my O2 sim the system works perfectly.
Does anyone know what the problem could be or how I might be able to fix it?
Christopher_G
Hi @The_cheatman
Welcome to the community.
Does the router work when you connect a device to it in the normal fashion?
Hi Chris,
Yes it appears to, I’ve only tried connecting my phone to run a speed test
which seemed to work ok, although getting no where near the speeds I was
told I would!
[Mod edit: Please do not post your contact details in this public forum. Thanks]
Christopher_G
OK, thanks @The_cheatman
It may be worth having a chat with our technical support team, so they can make sure everything is as it should be from our side.
