28-04-2024 08:18 PM
My hotspot is working for everything else besides my PS5. It has this message “You internet service provider or your router might be preventing your PS5 from connecting the internet…” please help!
29-04-2024 08:01 AM
Hi @MoonAb
Welcome to the community.
Have you tried restarting both devices? Has this previously worked for you?
29-04-2024 11:45 AM
Which mobile router have you?
30-04-2024 03:23 AM
Hi, @Christopher_G
Thanks!
Yes I have restarted multiple times. It has never previously worked I have to connect it to my mobile hotspot instead of the 4G WiFi for it to work.
30-04-2024 08:02 AM
OK, thanks @MoonAb
Sorry, I think I misunderstood. Are you saying it is working with the personal hotspot from your phone, but not your 4G WiFi device?
Have you tried forgetting the network and re-setting it up?
30-04-2024 09:38 PM
Hi, @Christopher_G
Sorry I wasn’t clear before. Yes I have tried that it always brings up the same message.
01-05-2024 01:50 PM
OK, thanks @MoonAb
I can only recommend speaking with our technical support team so that they can try and help you get connected.
