19-10-2023 04:18 PM
I have 2 contract with EE, Mobile contract and EE 5G Router. I am getting only 20MBPS speed on 5GE router while on mobile i am getting up to 70MBPS speed. I had a chat with EE and they told me , that could be a issue with your both sim. They send me both new sim but the issue still there. on same location 5G Router giving me only 20MBPS while mobile up to 70MBPS. I even change the router around 5 time as I was getting multiple issues with router. I confirm with EE, if there is any speed cap on my account and i been told that no speed cap on your account. This is really strange issue. I am a IT professional so i have much knowledge for troubleshooting. Even I put back router to 4G but issue still there. EE playing around by giving you some stupid suggestion. EE is using zyxl company Router and they put their own firmware which is locked, so you cannot even upgrade.
For my best suggestion, its time to leave this organization. how come both 5G devices give you different speed on same location.
19-10-2023 06:20 PM
Is the router SIM on contract or PAYG/pre-paid?
19-10-2023 08:48 PM
Contract.
19-10-2023 09:20 PM
@XZAFEE when you say the same location, do you mean in the same room ? and is your router placed near a electrical appliance like a television ? And have you tried putting your phone Sim card into the router and your router Sim card into your phone and tested the network speeds?
And are you testing your router speed via Wi-Fi or wired connection ?
23-10-2023 08:49 AM
Nothing near to router. i move router and phone multiple location. Mobile contract speed is around 60 MBPs while rother only 15MBPS or even less. I am sure they put speed cap on router sim. They just playing around. When I called I been told there're plan engineer work on my location. Absolute rubbish customer service. Both sim with same network on same location and speed is different and they are telling me " engineer work".
23-10-2023 03:22 PM
If that were the case then putting phone SIM in router, as sensibly suggested by @Chris_B , would remove that cap.
24-10-2023 10:15 PM - edited 24-10-2023 10:17 PM
You will be surprised what I done. I put my mobile sim in router and router sim in phone. Router sim get block while mobile sim working fine in router. After that I have reset the router to default. I also keep the same default WIFI password and default WIFI ID. once i change different WIFI id and password, speed goes back to 15MBPS. This is really strange. Anyways I am waiting for router sim to see what outcome come. I also asked EE, not to put any Speed cap on it, otherwise , I will leave my business contract.
24-10-2023 11:40 PM
Not really, it was suggested to you last week. The surprise is that it is impossible for the router's SSID & pwd to affect its speeds. However what will affect its speed will be which WiFi band, 2.4 or 5 GHz, you connect to.
10-03-2024 01:37 PM
Hi. I have exactly the same issue, with an ZTE 5g router. For a long while, I used to get better speed on the router compared to my phone, but in the last few months, on the router I only get half the speed I get on the phone. I switched the sim cards around and the same: on the phone I get 600 mbps and on the router close to 300 mbps. SO, if I got it right, you're saying that after resetting the router and not changing ID/ password, you get the same speed as you get on the phone? Sounds weird, but I'm ready to try anything at this point as it's driving me crazy, specially knowing that my router used to get really good speeds.
P.S. EE sent me a new SIM card already, but no difference
10-03-2024 08:07 PM - last edited on 10-03-2024 10:21 PM by MikeT
wahoo,
you need to check your router support after 300MBPS
Best Regards,
