14-02-2023 02:56 PM - edited 14-02-2023 03:24 PM
Hi community,
I've been looking at getting the 5GEE Router 2021 for a small business use case. I managed to find a User Guide, which said:
"The guest network is a temporary wireless network for guest users. You can set a duration you wan the network to transmit."
Among the settings options, it says
Temporary?! Does this mean someone has to log in and enable Guest Network every time anyone wants to use it?
Can anyone who has this router tell me - is there an option to just enable the guest network indefinitely? We would absolutely need this, and every other router I've seen does not put a time limit on guest networks.
What are the full options for the "Duration" dropdown? The user guide doesn't show them.
Captive Portal session timeouts I can understand (not that the 5GEE 2021 is capable of that, afaik), but just disabling the whole network after a set time would just not be in any way usable. If that's the only option, then we would most likely need to look for other routers, or providers without such locked-down features.
I would also be interested to know, if anyone has the Zyxel NR5103 - i.e. the same device but not locked down with EE's firmware - what the options are for guest networks.
Many thanks,
Will.
14-02-2023 07:02 PM
Hi @will-,
That's a great question. I've reached out to see if I can get some more information on the guest network feature for you.
I'll get back to you as soon as I receive a response.
