13-01-2024 07:39 PM
Does the EE Smart Hub offer:
Some background: I have an Echo device and growing number of IoT devices. To protect against network intrusion (from an IoT device into my home network) it's been suggested I should either put the Echo and IoT devices on a guest network or on a separate VLAN.
A more complex recommendation is three VLANs: home, devices, guest.
I'm currently on BT Broadband using a BT Smart Hub 2 which doesn't support:
It seems that I will be encouraged to migrate from BT to EE Broadband sooner or later. So I am trying to find out if the new hub will be better suited to securing my IoT network, before I start shopping for yet another device.
(I'm aware of Advanced Web Protect but that sounds more like a firewall, rather than internal security from a hijacked device. If there are more details on how AWP works I'd love to read them.)
13-01-2024 08:55 PM
The EE Smart Hub Plus does have 1 Guest network & VLAN. It does not support bridge mode/modem only.
13-01-2024 07:44 PM
Well, Setting up Guest WiFi sounds promising! That page says:
Guest’s devices are kept separate from your main WiFi to help keep your home devices safe.
That sounds about right. But are guest devices isolated from each other as well?
13-01-2024 08:55 PM
