22-01-2024 05:29 PM
Ive just checked my phone plan and I pay for 5g but I never get 5g as my phone is quite old.
Would you possibly be able to take this off and decrease the monthly price as I don’t use it?
I’ll look forward to hearing from you.
Kind regards,
Amy Pope
22-01-2024 05:42 PM
You don't pay any extra for 5G. All EE SIMs will work on whichever 'G' is compatible with your phone & with the signal in the vicinity.
Which phone have you?
22-01-2024 06:12 PM
Out of interest, what makes you think you pay separately for 5G? As per the previous reply, there has never been a separate charge, and EE's T&Cs specifically allow for access to whichever radio technologies are available.
22-01-2024 06:16 PM
No, but in the past there were 4G SIM plans & 5G SIM plans priced differently.
22-01-2024 06:26 PM
Indeed so, but my point to the user is that there has never been a separate itemised charge - hence my curiousity as to what makes them think they are being charged specifically for 5G access.
22-01-2024 06:34 PM
@bristolian : OP never mentioned 'itemised'. I believe OP just means 5G is 1 of the features of her plan.
