05-10-2023 07:24 PM
Had a data only SIM for 8 months total and for the first 7 months it ran with little to no hitches at all. In the last 30days the service where I am has crossed into unreliable at best. As for my phone having a weak service isn't too much of an issue but using a data only SIM in a 4g router becomes a literal waste of money.
Outside of cancelling and coughing up hundreds of pounds on something useless is there any sort of compensation possible? believe it or not I didn't sign up for a service that at times doesn't work at all.
05-10-2023 07:41 PM
As a first check, you should report the degradation in service - use the "check status" & "report a problem" link on https://coverage.ee.co.uk/coverage/ee and, if no resolution, via CS.
You need to give EE the opportunity to investigate and rectify your service issues first.
05-10-2023 07:47 PM
Already done and dusted, did all of that last week.
The narrative since then has changed from "what is wrong" to "how do I escape" as clearly no issue was found
05-10-2023 08:01 PM
The previous advice was based on the information first posted.
The broad brush answer is that the T&C's don't guarantee coverage in any location and that temporary faults are not normally a basis for fee-free contract cancellation.
I would recommend you continue to discuss your specific circumstances with CS. Ideally an issue can be identified and rectified.
05-10-2023 08:08 PM
That would be the best case, yes. I am somewhat assuming that EE wouldn't go out of their way for me hence I am already thinking about the multiple hundreds of pounds I would be screwed out of because of a unreliable service.
06-10-2023 08:16 AM
It's worth having a call to discuss this, @4ngu5.
Please come back and let us know how you get on.
