18-02-2024 02:06 PM
I have just moved from Plusnet to EE. With PN all my smart devices worked perfectly using home assistant. Now I have an EE router nothing will work. Even my nest thermostat is unresponsive. Anyone have any ideas/solutions, please.
21-02-2024 05:36 PM
I have managed to work it out. I have done a clean install of home assistant and added each device one at a time. Al is OK now . Thanks for your input. Much appreciarted.
Mebrew
18-02-2024 02:58 PM
Hi there @mebrew
Which EE router do you have?
Can you connect any other devices to the router?
18-02-2024 03:30 PM
Try on the Advanced > Wireless Settings page to temporarily disable the 5 GHz WiFi band & move off the Smart channel while connecting problematic 2.4 GHz devices.
18-02-2024 04:49 PM
@mebrew- are you able to provide some more information about how you have things configured (both before and after), what you are using to control Home Assistant, and whether or not Home Assistant provides any clues as to what's wrong when you log into it?
Doesn't help your situation, but I use Home Assistant to control various smart devices around my own house and have no issues at all when using it with an EE Smart Hub Plus.
18-02-2024 06:34 PM
18-02-2024 10:03 PM
The speedtest link in the Hub Manager is broken, so that's not you.
I'm still struggling to understand how your home network is configured? It sounds like there are some complexities that might be conflating things.
How have you reconnected your existing devices to the EE hub? Did you go round them all changing their Wi-Fi credentials, or have you done something else like change the SSID/password on the EE hub to match what you were using with Plusnet? Are you using any additional extenders, Powerline adapters or any other non-default networking equipment? What are you using to access Home Assistant and what is Home Assistant telling you? Have you tried going back to basics, disconnecting everything, factory resetting the EE hub, and connecting things one by one, checking each step of the way?
What hub were you using with Plusnet? Another option might be to reconfigure the Plusnet hub to use your EE broadband login credentials and see if that works.
18-02-2024 10:21 PM
19-02-2024 01:33 AM
The EE BB PPPoE Username/pwd is the same as BT's: bthomehub@btbroadband.com /BT or blank
19-02-2024 09:59 AM
@mebrew wrote:
When the router was first installed all I did was disconnect one and install the other, thinking that one BT device is much like any other. - but no.
Out of the box, the Wi-Fi credentials are going to be different with the EE hub, so some re-configuration is going to be required at your side to get your wireless devices reconnected.
The easiest option would be to log into the EE Hub Manager and change the Wi-Fi username/password (Advanced Settings > Wireless) to match the details of your old Plusnet router.
If you want to go the other route (reconfiguring the Plusnet router), then as @XRaySpeX has advised, you can use the credentials from the help page I linked to.
21-02-2024 05:36 PM
Mebrew
