Smart Hub Pro - How to change DNS settings?
goral
Valued Contributor
Valued Contributor
I am setting up Smart Hub Plus and want to change the DNS server to 1.1.1.1 but I don't know how, I can't find the option to change it anywhere.
Goole returns that the change is done this way:
Home > Advanced > My Network > IPv4 Config & switch DNS Servers Auto to OFF
But with me there is no such option in My Network.
Any help?
You can't as you've already discovered!
ISPs: 1999: Freeserve 48K Dial-Up => 2005: Wanadoo 1 Meg BB => 2007: Orange 2 Meg BB => 2008: Orange 8 Meg LLU => 2010: Orange 16 Meg LLU => 2011: Orange 20 Meg WBC => 2014: EE 20 Meg WBC => 2020: EE 40 Meg FTTC => 2022: EE 80 Meg FTTC (no landline number)
goral
Valued Contributor
Valued Contributor
Why?
This is one of the most important settings for me.
This supposedly super modern hub, and it turns out to be worse than what it was 5 years ago.This supposedly "smart" hub turns out to be a completely "dumb" hub.
Good thing I didn't get rid of the old one.
And is it at least possible to use this super hyper smart hub as a wifi extender?
Dunno! EE in their wisdom decided what it can & can't do.
goral
Valued Contributor
Valued Contributor
There is a chance to flash alternative software as from them: (DD-WRT)?
Who is the manufacturer of this router (HUB)?
