03-05-2024 01:21 PM
Hi there,
I currently have the eero system from Talktalk, but I would like to add an old ee router to extend out to my garage. This will be hard wired using a cat6 data cable.
I have watched YouTube videos on how to reset the router but eero has an iOS address 192.168.4.1 so when I put that address in, it then blocks me out, so I reset and try again, with same results…
thanks in advance
Jimmy
03-05-2024 02:33 PM
@Kawasakizzr1100 : Which EE router?
You are trying to do the reverse of what OP is doing. Is that right?
03-05-2024 03:04 PM
03-05-2024 03:13 PM
@Kawasakizzr1100 : You should set its Broadband Setting as Ethernet > Protocol = Routing.
