19-10-2023 10:15 PM
I am considering moving from Virgin Fibre Broadband to EE Fibre Broadband when current contract finishes.
However, we have no BT phone line inside our property, it’s connected from a telegraph pole in the street to our gable end but goes no further.
Will EE arrange further connection i.e cabling into our loft space and down to a connection socket in our living room?
19-10-2023 10:17 PM - edited 19-10-2023 10:18 PM
@WBAbaggiesfan Yes they will. You’ll probably find that the cable from the pole has to be replaced also, I had this done when I switched to EE BB.
20-10-2023 01:45 AM
No new landlines are being sold now. You could order EE Fibre BB without Landline.
20-10-2023 09:44 AM
@WBAbaggiesfan you need to be very careful and make sure you do your research and make sure any move to another supplier can provide the services and speeds you need. As mentioned the old phone network is no longer available to new customers, but a new digital service may be available in some areas, but no all. Also speeds available over copper lines may not be sufficient for your needs.
To see what EE is able to offer scroll down the following page and enter your address. https://ee.co.uk/broadband
Bear in mind other suppliers that do not use the Openreach network may also be available - has anyone been digging up the pavements near you?
