29-02-2024 08:50 AM
I have gone onto hub manager and switch off internet (while connected to wifi). However now I cannot get back in to hub manager (not connected to wifi) to switch back on. Any suggestions?
29-02-2024 09:37 AM
@Mac1980 first suggestion would be don't do it again.
Have you tried switching the router off and then on again?
If that does not work, try th reset button at the rear, keep it pressed for up to 30 secs or until the lights change.
HTH
