24-01-2024 12:43 PM
Hi there
is there a way to turn on a phones locating device remotely at all? Trying to locate a lost phone ?
do I need to ring we to sort it out?
thank
24-01-2024 12:47 PM
Do you have find my mobile enabled?
What phone is it?
24-01-2024 12:47 PM
There's two ways you can locate a lost phone.
1: If you have already enabled location-finding services from Apple or Google, use those. They often include an option to override any "silent" or "DND" modes. You can't enable this remotely, that would be impossible by nature of remote access being off.
2: Call the phone and listen for the ringtone.
EE CS have no means to locate the phone other than by the above two methods.
24-01-2024 12:52 PM
@Shaft2 Login to your iCloud account via a pc and use find my to locate your device z.
