14-03-2024 05:36 PM
If my phone has eSIM activated and I have to send it off repair how can I get temporarily transfer the number onto another phone?
15-03-2024 07:53 AM
Hi @pgriffinuk1
Are you sending the repair off through the EE Store? If so, they'll be able to give you a replacement SIM or eSIM there and then. Once you get your phone back, they'll be able to give you another eSIM for that.
15-03-2024 09:48 AM
15-03-2024 02:08 PM
Ah, OK thanks @pgriffinuk1
What kind of phone are you sending for repair, and what kind of phone will you be using temporarily?
15-03-2024 03:14 PM
Thank you @Christopher_G
I will be sending an iPhone 13 Pro off for a charging repair
I will temporarily be using an iPhone SE 2nd gen (2020)
15-03-2024 03:50 PM
Good stuff, @pgriffinuk1
You should be able to transfer the eSIM through the 'quick start' setup on the iPhone. There are some instructions here on our 'What is an eSIM?' help page under the replacement section.
15-03-2024 03:55 PM
Thanks @Christopher_G
Unfortunately as the main phone cannot be charged it seems the temporary phone doesn’t allow that method of transfer!!
15-03-2024 04:00 PM
Ah, OK @pgriffinuk1
In that case, you may need to order a replacement SIM either through our Mobile Care team, or in your nearest EE Store.
