08-05-2023 09:49 PM
Hi I’m having problems with charging my iPhone 12. The charging port seems to be faulty as when the charging cable is plugged in, a small movement causes charging to stop. If I fiddle with the cable, it starts to charge again! I’ve tried several cables with the same issue.
08-05-2023 10:06 PM
If you got a tooth pick use that or switch phone off and use a staple to clean the charger port but be really careful
09-05-2023 09:49 AM
