22-03-2022 07:55 PM
I have a passcode on my phone which i can't get past as i have broken the screen where some of the numbers i need are. Is there any way a passcode can be removed?
22-03-2022 08:17 PM
Hi @Lynseyb24
Do you have an Android phone or iOS?
The answer is substantially the same regardless - lock screens are designed to only be unlocked by the authorised user of the phone.
Android has at least, has remote unlock facilities if you've enabled and setup the option in advance - and I suspect iOS is probably similar.
Otherwise try taking a read of this article but be prepared to lose all your data. The PIN is there to protect that.
22-03-2022 09:52 PM
Hi @Lynseyb24
Log into your main Apple/Google account and if you backed up your numbers should be saved online.
22-03-2022 10:02 PM - edited 22-03-2022 10:03 PM
@Lynseyb24 If it’s an iPhone
Step 1 : Open the Find My app on your iPhone, iPhone, or other Apple device. You may need to log in. Otherwise, you'll be brought to the main menu.
Step 2 : Find and click on your iPhone in the list of devices.
Step 3 : Click on Erase iPhone.
Step 4 : Once the iPhone is erased, you'll be able to set it up as a new device or restore it from backup.
The problem you have is setting it up with a broken screen if it’s not recognising touch responses so you have issues setting it back up.
