11-04-2022 05:30 PM
HELP! The WiFi on my A52S keeps going to 'connected without WiFi' I then can't get any Internet at all because it won't switch to mobile data.
11-04-2022 10:15 PM
Hi @Johnmk69
Is mobile data enabled on your phone?
Do you have an available WiFi-hotspot in range, when you get this error?
05-05-2022 01:20 PM
Hi @Johnmk69,
Did you find a solution to this issue? I have the very same problem with the wifi connection dropping out every so often. The only way I have fixed is to switch off/on the wifi.
Thanks!
05-05-2022 02:20 PM
My First call for this would be the Battery Saver, go to Battery Saver Settings it should allow you set what happens to various Apps and Phone Settings and select your preferences when Saver is on or Crutial, having said that its a Samsung so the settings could be hidden anywhere within other Samsung Settings.
