Voicemail missing
WightMan75
I have a Galaxy A41 on a PAYG account.
I have just noticed voicemail has switched off and text VM ON doesn't work.
Any suggestions?
14 REPLIES 14
@WightMan75 Try texting VM OFF to 150 then restart the device then try VM ON to 150.
 You could also try VOICEMAIL DIVERT ON to 150
I'll give that a try
Now this is curious!
VM off gets a positive response.
The two methods for switching voicemail on both get:
Sorry, we're having some trouble completing your request at the moment. Please try again later.
On the plus side:
EE have upgraded my community badge 🎉
Northerner
Hi @WightMan75
Try restarting your device and trying again.
To contact EE Customer Services dial 150 From your EE mobile or 0800 956 6000 from any other phone. You can call Freephone +44 800 079 8586 on Skype
EE standard opening hours are 8am to 10.30pm every day.
No joy with that.
Bring back CTRL-ALT-DEL! That always  worked. 🙈
Legend
Legend
In what way is your voicemail "switched off"?
Are you unable to gain access to it by calling 222 or speed-dial 1? Or are the auto-diverts on incoming calls not working?
Thanks for your advice.
When someone calls and the phone is not answered the incoming caller is told the recipient is unavaiable.
They are given no opportunity to leave a message.
I haven't tried 222 yet. I will.
222 gives me access to voicemail options.
What's next?
Legend
Legend
Calling 222 is the means to access your voicemail.
If the issue is with incoming calls not diverting, you should be able to set them manually via your phone's call divert settings - you're looking for the "divert when busy, unreachable or unanswered" option to set a divert to +447953222222
