24-11-2023 02:29 PM
How to make longer ringtimes on a Samsung galaxya04s, it’s for my 95 year old mother in law, or is 25 sec all you can do?
thanks in advance
jane
24-11-2023 03:36 PM
Welcome to the community.
The network standard is 20 seconds before it diverts to voicemail, I believe. You could remove the voicemail, which would mean the phone would keep ringing. To do that, text VM OFF to 150.
24-11-2023 04:05 PM
Historically the standard was 30 seconds with an option to alter that in 5 second increments using MMI codes.
Realistically, 25 seconds may be your best compromise unless you disable voicemail entirely.
24-11-2023 04:14 PM
Tried codes and was unsuccessful, think they would work on a different Samsung galaxy though
thanks
