30-09-2022 07:50 PM
I changed my Tmobile SIM card(3G) to an EE SIM card(4G) , porting my old number etc.Turned phone (Samsung) off overnight
The following day after porting, turned phone on, only to find the configuration on my phone had changed e.g. lock screen , notification settings etc.
Is this a common after porting or is it because I moved to a 4G SIM card ?
P.S.New to the community and this is my first posting !
01-10-2022 03:30 PM
I don't think it's anything to worry about, @inhousetech. If you are worried about anything, you could always back up and restore to factory settings.
01-10-2022 09:09 AM
01-10-2022 03:24 PM
Hi
Thank you for your welcome
I think it must have done a software update as it asked me to set up my lock screen again.
What puzzled me was that I normally get a notification from Samsung, to say that an update is available and this time I did not .
I have not noticed any other changes since, but it was unnerving to restart my phone in the morning and see the alterations !
01-10-2022 03:30 PM
