24-08-2023 12:22 AM
All ready got the 16 digit unlock code from ee site & had it emailed
Got a free sim from giff gaff, activated it online including setting up an account, but not setup payg or monthly & no intension of doing so. All I want to do is unlock my phone from EE. When I put the giff gaff sim in I am greeted with a message Sim network pin blocked. Enter sim network puk
Entering the 16 digit number I get network unlock unsuccessful, have double checked not got 6 or 9 mixed up - not mixed them up
Phone was bought outright directly from ee in 2017. I guess calling 150 will get the same 16 digit number. Any viable soulutions
24-08-2023 08:17 AM - edited 24-08-2023 08:18 AM
Hi @Guest_Guest
Welcome to the community.
The PUK code is different to an unlock code. It sounds like the PIN number for the other network's SIM card has been locked and you would need a PUK code from them to unlock it and set up a new PIN. Once that's done, you should be able to enter the unlock code provided.
Hi @Guest_Guest
03-10-2023 02:30 PM
I have just got an unlock code but have been unable to find anywhere to enter it
03-10-2023 02:52 PM
This would be enter on the device you want to unlock when you have another network SIM card installed and are prompted for the code.
27-12-2023 09:04 AM
My s10 is showing Network Code Blocked because you have entered the wrong many times. How do I fix this I want to use other networks on my phone.
27-12-2023 10:53 AM
27-12-2023 11:00 AM
Network unlock code blocked. Too many incorrect attempts.
27-12-2023 11:08 AM
Does it ask you to enter a MCK code, @Cyberjay?
27-12-2023 11:23 AM
Yes. It showing enter MCK.
27-12-2023 11:40 AM
Hi @Cyberjay,
On this screen, enter the last 8 numbers of your unlock code. On the following screen, enter the first 8 digits.
Hope this helps.
