08-05-2023 12:24 PM
EE says to link to a laptop, open webbrowser and key in 192.168.1.1.
Despite other sites being open, get address not found!!
Surely there is an alternative to this generic archaic URL
I just want to back up my mobile and settings.
08-05-2023 12:38 PM - edited 08-05-2023 12:41 PM
Which mobile are you trying to back up?
That IP is usually for connecting & managing a router.
The usual method for linking a device to a lappy for transferring files between them is by using a USB cable and the device will appear as an additional drive on the lappy from which you may copy or move files.
08-05-2023 12:46 PM - edited 08-05-2023 12:47 PM
Thanks. Can't believe they assume everyone has the same router address, or that a router will store your mobile settings, lol.
08-05-2023 12:52 PM
