22-01-2023 02:27 PM
Phone Model: Sony Xperia M2 D2302
So, another of these posts...
After having come out of Airplane mode when I returned to the UK my phone decided to no longer transmit or recieve any mobile data.
I've gone through the usual steps of restarting, SIM re-insertion, Airplane mode faff, resetting of all APNs and manually getting it set back up as well as using the online service to get the automatic install sent over (https://setup-ee.wdsglobal.com/internet).
As this has happened once before many years ago and magically fixed itself when I changed my pack I have the weird feeling the problem lies most likely with EE.
22-01-2023 03:12 PM
Presumably PAYG?, how long have you been out of the UK?, Pack Expired or not renewed?
22-01-2023 04:02 PM
Given the reference to packs in the original post, then PAYG hibernation is indeed the first thing to check.
Please read the first post in this thread and confirm when your last chargeable action was.
24-01-2023 07:09 PM
I was still using Data earlier that morning before getting on the plane, so highly unlikely to be forced into hibernation. Also just renewed the pack a week prior.
24-01-2023 07:18 PM
For reference, and taken from the page I linked to, "Calls, texts and data usage made using your allowance from your pack do not count towards a chargeable activity"
Pack renewal I believe does count.
24-01-2023 08:29 PM
Just using data isn't a chargeable action. You needed to make a chargeable action like making a chargeable call or text, topping up or buying a Pack or Add-on, not just using your mins, texts or data from your pack.
24-01-2023 09:57 PM
I would assume renewing a pack is considered buying a pack? And I just topped up to buy said pack.
Normal phone activity is still functional thus hibernation seems highly unlikely.
24-01-2023 10:04 PM
Yes, to renew it you have to pay credit for it.
25-01-2023 04:49 PM
So hibernation is very unlikely to be the issue as I mentioned a few posts ago.
25-01-2023 05:02 PM
Thanks for getting back to us @nativevs.
If you place your SIM into another device does it work?
Katie
