How to get Esim for new tablet
NDDLB
Hi, I added a Samsung galaxy s9 ultra to my plan and it arrived fine but I've not been sent a QR code for the esim for the plan that I opted for so I am unable to set up the sim card. I ordered a replacement sim card which came but when I tried activating that all I managed to do was switch my phone plan over to it instead of activating it which I didn't want to do as ive now had to put that sim card in my phone instead of my tablet...
How do I go about getting the tablet plan activated so I have signal on my tablet? I assumed it would come with a QR code but it didn't. Will I need to order a replacement sim and somehow activate that?
Katie_B
Hello @NDDLB
Did your tablet come with a physical SIM?
Have you switched the tablet on? if yes, is their any prompts to set up your eSIM during set up?
Katie
It didn't come with any sim at all, and if I click search for esim on the tablet it says there isn't any found
Katie_B
Thanks for confirming @NDDLB
Have you tried logging in to your EE account and downloading an eSIM from there?
If not please log in and see if this an option.
Speak soon,
Katie
It does not come up as an option but I managed to get a physical sim and have them activate it over webchat so it's thankfully sorted
James_B
Thanks for the update, @NDDLB 🙂
