22-09-2023 01:41 PM
How do you move all apps, pictures etc from Android huwaei to an iPhone?
Cheers
22-09-2023 01:59 PM
@Craigs2 You’ll need to download the apps you want as it’s two different operating systems. so any purchase apps will have to be purchased again
When you start up the iPhone, it will give you a chance to set up from an android device.
22-09-2023 06:19 PM
Hi @Craigs2
In addition to the points @Chris_B makes back up your data to google drive, one drive and then you can add the account to your iphone.
22-09-2023 09:09 PM
@Craigs2 - There is an Apple app for that - Move to iOS.
https://play.google.com/store/apps/details?id=com.apple.movetoios
