18-04-2024 11:42 AM
I had youview before from TalkTalk. Is it correct? You can still record Freeview channels as well as IP channels at the same time?.
audio description, is it available on the IP channels?
I have a special offer with NOW TV, which ends in September, if I went out to yourselves, would I still have to pay NOW TV until my special offer comes to an end , or would you sort it out?.
I have two Apple TVs, which works really good for Accessibility? Could I still use the Apple TV box as well as the EE TV plus box for recordings? Because not everything is on catch up yet. And NOW TV on demand doesn’t have audio description.
can you control the TV plus box by the EE app? for example change channels, because I had to play around with the app last night, it’s completely assessable on my iPad and iPhone. it would be useful to use then the remote control as the TV box doesn’t have text to speech on the EPG.
thank you for your time, prescol
18-04-2024 12:09 PM
@Prescol wrote:I had youview before from TalkTalk. Is it correct? You can still record Freeview channels as well as IP channels at the same time?.
Yes
Yes
When you switch to EE, the billing would switch to EE. I don't believe the special offer price would carry through, and if you're tied to a contract, you may be required to pay an exit fee - I'm not totally sure on this.
Apple TV boxes you already own would not be able to receive the full EE TV experience - you'll be restricted to just store and sport channels. Only an Apple TV provided as part of an EE TV contract would get access to all Freeview and IP channels. You cannot have an Apple TV and a TV Box Pro on the same contract - it's one or the other.
The mobile app cannot be used to control the TV Box Pro I'm afraid. You can control the box using accessibility devices connected via USB though: https://support.youview.com/youview-box/accessibility/accessibility-features/
19-04-2024 06:12 PM
I wouldn’t till ee sort out billing tv and apps as may not get what you pay for.
I been waiting 5 weeks
20-04-2024 06:08 PM
Unless you absolutely must record an IP delivered stream, I wouldn’t touch EE TV with a barge pole if I was you.
