04-07-2023 03:21 PM
I’m getting “a incorrect number, please try again”
04-07-2023 03:49 PM
Hi @TheWiseOldMan,
When did you put the new EE sim in your phone?
Have you rebooted your phone since putting it in?
Also, did you transfer your number via PAC code? If so, when did you do this?
Thanks,
Alex
04-07-2023 04:10 PM
Put the card in this afternoon.
the phone has been rebooted
the shop assistant carried out everything on saturday last and said the set up should be okay for today
04-07-2023 04:56 PM
