27-03-2022 04:52 PM
I just upgraded to the Google pixel 6 pro. I was wondering if it should have come with a charger?! None of my charger plugs work with it. I have wireless chargers but they're faulty and not charging properly. I can buy one but would assume I should have had one sent with the phone?
27-03-2022 05:08 PM
Hi @CarysB90
You'll need to buy the plug from Amazon. It is USB type C and the power cable comes in the box, just no plug.
13-10-2022 08:35 AM
Google Pixel 6a is a con. I bought one and it made out it was wireless "QI" charging online so I ordered a pad but it's not. Then no charger was included and same problem that it won't charge with other chargers. I found the correct 18 watt USB-C charger eventually but shan't buy a Google phone again.
