29-07-2023 08:30 AM
Good morning everyone,
I need some help as I can’t use my sim card in Switzerland.
I have 4 g activated but no internet connection,and I can’t send or make any calls as they are barred. I’m not able to to send any messages as I wanted to buy £2.50 to activate it to use it for internet.None of them are working despite of having £15 credit. I am new to EE but never been explained anything,just been told that it’s all activated for EU and Switzerland.
Can anyone would be able to help asap.
Thank you
29-07-2023 08:41 AM
Using a phone abroad is called roaming, what matters is to have roaming enabled. Your post sounds like you're on PAYG, in which case roaming is auto-enabled after your phone is used in the UK first.
If roaming is enabled, then changing the local network you're connected to, often resolves connectivity issues.
29-07-2023 08:59 AM
The simcard had not been used in UK.
Never been explained that I need to activate before going out of UK.
Anything that can be done?
29-07-2023 10:28 AM
Hi @Cras2h
Nothing can be done. EE is a UK network hence activation needs to be in the UK. Roaming is a benefit.
Once you are back in the UK you can activate the SIM.
