03-05-2024 10:03 PM
I'm in Orlando on holiday. We've paid for roaming as an add on. This is on my daughter's iphone 12. Roaming is switched on. However her phone will not connect to a network. Any ideas?
03-05-2024 11:18 PM
As you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming billing add-on doesn't of itself activate roaming on your a/c. Having roaming activated on your EE a/c, not just on your device, is crucial to using your contract SIM abroad.
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
03-05-2024 11:32 PM
To add, where specifically is roaming switched on? The only place it is selectable is on your SIM within EE CS.
You may be getting confused with "data roaming" as a menu option on your phone, which enables mobile data usage whilst already roaming.
If you are on pay-monthly and now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 0798586 using a web-calling app such as Skype over WiFi.
