02-05-2024 09:17 AM - last edited on 02-05-2024 09:37 AM by rvince
I am in Saudi Arabia , I want to activate roaming service for number [edited]. I don’t want data , I want to receive and make text and receive and make call. I have seen the applicable charges. I will be in Saudi Arabia for one week only. Thanks
[Mod edit: Please do not post your contact details in this public forum. Thanks]
03-05-2024 11:47 PM - edited 04-05-2024 12:01 AM
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
03-05-2024 11:58 PM
If you are on pay-monthly and now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 0798586 using a web-calling app such as Skype over WiFi.
